We know that we have now modern and accurate simulation tools
We already know that the car has done on track what the tools were predicting
Then, this is now a different story from past years and as this tools are the ones we are using to upgrade the car, be sure we will have working updates this time
The new ferrari wind tunnel has made a world of difference the old one cost ferrari dearly,with correlations differing greatly between wind tunnel data and track data.Now fully equipped I expect ferrari to be at the pointy end of f1 for quite some time,in addition a change in how ferrari operates and the complete methodology of the organisation being overhauled by binotto makes the new ferrari a formidable indeed,current results speak volumes.
Yes, positive thinking is the way forward and so far so good, so I'll do my best to remain optimistic as well as being realistic, but you are quite right regarding Binotto's overhaul of the team and its mentality. I'm glad we have him after all the doubts of the past few years.![]()
F1-75 is overweight by 10KG, Red Bull and Mercedes are both 15KG over the minimum weight, according to AMUS.
We still haven't fixed the bouncing effect completely, plus the engine isn't at it's maximum, Ferrari will gradually increase the power. There're plenty more lap times to unlock from the base design itself. And then there are upgrades.
I read somewhere that Red Bull will do it.If you give me a source that Ferrari will do the same then we agree.
More important to me is balance than total weight.If it was the weight then Williams could make the lightest car and take the championship.Is not that simple.
I said it doesn't mean anything.
Weight is the enemy in racing. A team can tune the balance, but the weight is weight, and physics are physics. 10 kg is significant. If a team could get that down to 780 kg and have 18 kg of ballast to move exactly where they want it, they would give a measurable advantage.
Again, I don't get your reasoning. For racing cars, weight is a big factor. Being overweight means giving away free lap times. Everyone on the grid will try to get closer to the minimum weight limit.
Ferrari is keeping quite about their upgrade plans. Red Bull or Marko likes to run their mouth to the media. Just cause Ferrari is keeping quite doesn't mean they don't have any upgrades in schedule.
I think we should remain calm and trust the team. They know what they're doing.
And again ... you come so negative.
Who told you that we're gonna be the only (ONLY?!) overweight team?
Who told you that we're not working towards solving this ?
Who told you that even we reduce the weight but we stay overweight, when (not if) we solve the porpoising issue and unlock more of the power in the engine, this will make zero difference ?
.. and so on.
Aero upgrades in Imola, full engine power in Miami. Imola upgrades should solve the porpoising issue, which will unlock more performance. Ferrari's goal is to increase aero efficiency, meaning more downforce and less drag.
This is sort of an oxymoron is'nt it??? How can you have more downforce (which the car was already draggy at Jeddah meaning it already had a somewhat higher downforce then.....so more downforce than Jeddah???) and less drag????
I could understand less downforce = less drag as opposed to more downforce = more drag and higher degradation.
Typo maybe????
These are the rumors I'm seeing.
In Imola, Ferrari is planning to introduce some lightweight parts (to reduce the weight of the F1-75 by 3kg) & we will see the first upgrades aimed at the aerodynamic efficiency of the car.
In Maranello they are also working to reduce the drag (to be able to match the top speed of the RB18)
Motorsport Italy says that Ferrari will introduce a new updated floor in Barcelona, which is supposed to reduce the porpoising significantly.
https://it.motorsport.com/f1/news/f1...fondo/9629227/
How can it be oxymoron? First of all, let's say, what do you understand by more efficient engine? If engine X is more efficient than engine Y, in a simpler term, it means that engine X is producing more power than Y while both consuming the same amount of fuel. Or, engine X can output equal power while consuming less fuel than engine Y.
Same with aero. The downforce and aero is at ratio of 1:1. So again in simpler term, it means more downforce = more drag. So increasing the aero efficiency means, more downforce = but less drag. The F1-75 produces good downforce but produces healthy amount of drag as well. But with upgrades, Ferrari will reduce the drag while increasing the overall downforce, making it more aero efficient.
Realistically that is the goal of every car designer.. to increase downforce while reducing drag. Tifosi1993 is correct. there are ways of making downforce that are more efficient than others. Most efficient way to get downforce is through ground effects.. increase the efficiency of your floor and you can reduce the downforce needed from your wings therefore reducing drag.
I am 100% convinced that Ferrari want to be absolutely sure that upgrades will work the moment the bolt them on the car.
They have a very simple floor, even simpler underbody venturi tunnels.
But their body is well studied (or at least it looks lie it is). So, I reckon they want to have all the data in their hands prior to any decision. I believe that the will decide right after Australia and then proceed to the upgades. That's why they will go to Barcelona for the floor.
I read about a 3kg weight gain and aero efficiency work to be done at Imola, a new floor to reduce porposing at Barcelona and a power boost with the second PU only after the Miami race. It seems like a development plan well in line with the situation, as they already have a winning car, a budget cap to respect, a top speed disavantage, 21 races to go and a few points advance. They could also bring reworked aerodynamic parts here and there to quietly evaluate with method certain directions of development without blowing up costs. Maybe RB can take advantage by updating their car faster, but we have to remember that it can't be final and not worry too much and too soon (I think to those who can't be patient)
I read somewhere that the FIA has declared that the goal of reaching engine parity has now been accomplished. I wonder if this means Ferrari will be very careful in turning up the wick on their engine to avoid suspicion should they now have the fastest engine?
https://www.formu1a.uno/ferrari-in-a...o-della-f1-75/
New floor and FW in Australia for validation purpose. If it works from the get go, they will keep it. Should improve aero efficiency and eliminate the porpoising effect.
