Page 17 of 63 FirstFirst ... 34567891011121314151617181920212223242526272829303142 ... LastLast
Results 481 to 510 of 1861
Thread: 2018 F1 news
  1. #481
    I still think the halo looks ridiculous.
    yep, with the Halo obscuring the Driver's helmet, car number clarity is important this year to distinguish team mates.
  2. #482
    My thought exactly !!!!!!
    Maybe, they can color the halo to the color of the helmet, so it has similar colors to the helmet, or the the flag of their country.
  4. #484
    I second that, its ugly. Gimmic, like the DRS. It wont stop pieces going to the face, like what happened to Massa.
  5. #485
    Spot on!
  6. #486
    Worcestershire
    True, this is just to stop wheels hitting drivers like with Henry Surtees, or accidents such as Maria de Vilota and Jules Bianchi. it's ugly and I hate it but it will save the life of a driver in those specific circumstances.
    Also I think they have plans to insert a screen onto the halo to use it for advertising, so maybe can also display the driver number/name intermittently.
  7. #487
    That's quite a rake the RB has...
  8. #488
  9. #489
    Quote Originally Posted by scudieros View Post
    tyres are triple tethered to the car so a tyre hitting that area is remote at best. Bianchi's crash is another matter.....one of those that we will probably never see again, a freak crash.
  10. #490
    It's not just to stop tyres hitting a driver and killing them though.
    Seaside
    Isn't it funny how this year every driver is making a helmet reveal, the same year in which the stupid halo will cover their heads.
    They should have known better, utterly useless.
  12. #492
    RIP Onboard because of HALO.
  13. #493
    Feb 2017
    Ireland
    From Gary Anderson "Has bold-looking Red Bull repeated its 2017 mistake?" anyone has a copy of the article? :)
  14. #494
    Quote Originally Posted by angeljr View Post
    Never mind, it's Gary, don't bother reading that
  15. #495
    Feb 2017
    Ireland
    Quote Originally Posted by Rishu View Post
    Seems the guy has lost it's reputation
  16. #496
    Apr 2015
    INDIA
    Gary Anderson Post
    To have any chance of winning the world championship this year, Red Bull must start the Formula 1 season strongly. It threw away 2017 with both its initial performance and its poor later-season reliability problems, but on the positive side proved it has the infrastructure to overcome these problems. The trouble is, the others don't sit around and wait.
    Daniel Ricciardo and Max Verstappen are both ready to put up a championship challenge, but they need the tools to do the job. With Renault suggesting last year it will not be supplying Red Bull with power units in 2019, this might be their last opportunity for a while.
    While he was tinkering with various other projects this time last season, I'm pretty sure technical chief Adrian Newey will have been fully focused on Red Bull's 2018 car right from the get-go. We expected a lot from one of the most highly rated aerodynamicists for the start of 2017 but it wasn't there. So will '18 reverse that situation? Let's have a look.
    It's always difficult to see things in detail when a team puts a lot of effort into camouflaging the initial car. Perhaps this is something Red Bull has learned from new partner Aston Martin.
    The front wing assembly is the customary multi-element component, but with a more uniform slot-gap placement than we have seen on the other cars. By that I mean the chord lengths of each component from the leading edge to trailing edge are more parallel.
    These slot gaps are all there to control the airflow separation and, more importantly, allow recovery from any separation problems. The more control you have over this, the more consistent the aerodynamic loads from the front wing assembly. Also, any turbulence coming off the trailing edge of the front wing due to airflow separation will have a detrimental effect further downstream.
    Red Bull also has an S-duct with the entry under the nose and the exit halfway up Ricciardo's number '3'. This S-duct helps pull airflow across the FIA-defined neutral central wing section, improving the mass airflow to the bargeboard area. It also reduces the lift created on the top of the chassis by the airflow accelerating over the top surface.
    Red Bull has also retained its 'driver cooling duct' in the front of the nose. This helps with the stagnation point of the airflow on the leading edge of the nose. The stagnation point is where the airflow decides whether it is going to go over the top of the nose or underneath it.
    Last year at the first pre-season test, I said I didn't see the 'wow' factor, and I have to say I also expected more this year
    Behind the front wheels, things get a bit more distinctive. The initial bargeboard package is a large vertical three-element component with a horizontal outer vane holding them all together. The car also has a curved lower foot area helping to better prepare the airflow for the underfloor. All of these are to pull more mass airflow through from under the front of the chassis helping the performance of the front wing and the leading edge of the underfloor.
    The outer bargeboard area is a vertical four-element component mounted as wide as possible on the outer corner of the sidepods. This area is all about managing the turbulent airflow coming off the trailing edge of the front tyre and trying to keep it away from the leading edge of the sidepod and underfloor.
    As opposed to last year's Ferrari, which had a very high letterbox style radiator inlet, Red Bull has gone for a narrower and taller inlet. The leading edge of the sidepod has the customary lower undercut, but it is not as pronounced as the other cars we have seen and this undercut doesn't continue through the sidepod.
    Instead, Red Bull has gone for a very narrow overall sidepod section angled inwards from the floor to the top. This will entice the airflow coming over the top of the car to be pulled down into the Coke bottle area inside in rear tyres.
    There is also a horizontal wing section developing out of the top leading edge of the sidepod, which goes out to the maximum width of the car. This profile twists downwards with a small endplate on the upper surface. This component is also helping the airflow to sweep down into the Coke bottle area.
    The Coke bottle area and the rear body section is fairly run of the mill, with the radiator exits being a T-section at around top rear wishbone height. Again, this not as exaggerated as we have seen on other cars.
    Red Bull continues to run the car with a very high rear ride height, which we call rake. This improves the performance of the front wing at low speeds when the rear is high and the front low - then it tapers off as the rear gets closer to the ground at higher speeds.
    It also means that the rear diffuser doesn't stall as early, again helping to move the centre of pressure rearwards as the car increases speed.
    We must wait until the Barcelona test to see the rear of the car in detail, and as the diffuser is one of the dominant components that makes up the aerodynamic package it will be interesting to see what Red Bull has come up with there.
    Last year at the first pre-season test, I said I didn't see the 'wow' factor with the Red Bull, and I have to say I also expected more this year. The car again has all the necessary bits and pieces but there is no stand-out component optimisation that I can see.
    As I said above, Red Bull needs to start the season strongly if it is to have a chance at another championship. And from the chassis, it might just need more than what we see here to achieve that.
    The other worrying factor for Red Bull is where the 2018 Renault engine package is at. It needs to be a lot more reliable at higher performance levels and Renault must unlock more one-lap power, especially in qualifying, to challenge Mercedes and Ferrari consistently.
    Renault has struggled throughout the V6 hybrid regulations and I'm pretty sure Red Bull will be expecting a lot more from it in 2018.
  17. #497
    Feb 2017
    Ireland
    Thanks for pasting here :)
    Let's wait for our car, I really do hope we have some good new innovation! Forza Ferrari!!!
  18. #498
    India/New Zealand
    Can some one plz translate this article??
    https://it.motorsport.com/f1/news/fe...ianco-1006196/
  19. #499
    i don't know if any of you guys take notice of bookmakers' odds, but have you seen RBR are 2nd favourites to win WCC?
    I guess this partly due to Kimi not scoring enough points last year, but considering Renault's reliability issues it may seem a bit optimistic. Unless they know something we don't?
  20. #500
    Quote Originally Posted by gvsnraju85 View Post
    It says, a darker tone of red accompanied with some light gray on the livery... no white it seems and there will also be a bigger emphasis on Philip Morris as their main sponsor.
    The article also states that Philip Morris is apparently making a big push for getting back smoke adds in F1 in the form of E-cigs...
  21. #501
  22. #502
    Rised uper arm on the front suspension.
    Will we have it too??
    RedBull also has it "kinked" forward right before it goes into the chassis.
  24. #504
  25. #505
  26. #506
    Looks a tad conservative compared to what we have seen so far.
  27. #507
    hong kong
    Ricciardo crashed the RB14 yesterday
    http://www.gptoday.com/full_story/vi...cciardo_crash/
  28. #508
    Yuma, Az
    That sauber has inlets and air ducts everywhere. Really aggressive for Sauber I feel like. Love the color scheme too.
  29. #509
    Quote Originally Posted by bondilad View Post
    Disappointed Since 2010
  30. #510
    AND HER NAME IS
    Attachment 7362
