Thread: Scuderia Ferrari SF70H
  1. #1531
    you know what, forget about RedBull as I spoke to soon. Hot off the press:
    Red Bull has no answers for gap to Mercedes, Ferrari
    source: https://www.motorsport.com/f1/news/r...errari-893389/
    Now we need Mercedes to feel the same
  2. #1532
    They went with low drag Now they are finding themselves in no mans land
  3. #1533
    Machu Pichu
    Quote Originally Posted by vetalo View Post
    From AmuS rough German translation
    What does Ferrari have in the floor?
    As soon as Ferrari is victorious, the competition looks more closely. She wants to see that the underbody, the rear wing and the diffuser bend during the ride. There are no more than indications.
    13.04.2017Michael Schmidt
    As soon as Ferrari is again a team that can win, the opponents look twice exactly. The new Ferrari SF70H is an all-rounder. It is fast in heat and cold, on hard and soft tires, in slow and fast turns. And the question is, how is that possible?
    Mercedes-Teamchef Toto Wolff was impressed by the road situation of the Ferrari in the fast corners 7 and 8 of the Shanghai International Circuit: "The drivers steer once, the car is like a board and drives without twitching through the curve." Daniel Ricciardo "The Ferrari often do not go to the edge of the track at the corner exit. This shows that they still have reserves. "
    Suspicious carbon strip in the Ferrari underbody
    The first rumors appeared in the test drives. As a Ferrari on the under-floor integrated a 2 meter long carbon strip with temperature sensors, the competition was noisy. After 6 days, the carbon texture was again uniform. To this day one does not know what was concealed behind it.
    The competition teams still did diligently photos, also on the course. According to her testimony, this shows how the undersurface has bent downwards at the sides and thus forms a kind of tunnel to the road. This could help to shield the flow under the car beautifully to the outside.
    The photos showed even more. Supposedly with top speed also the tail wing with diffusor bowed to the rear. In this way one could increase the top speed without having to abandon downforce in the curves.
    One-piece Ferrari floor divided into three segments
    In Shanghai, some of the teams saw their suspicions confirmed: An engineer told us: "There were slow-motion recordings from Raikkonen in the training, with the ground actually bent down on the sides."
    However, the effect does not exceed the full width. The FIA ​​measures the stiffness of the ground at two points. Front on the skid and on the edges just before the rear wheels. These tests consist of the Ferrari. However, the bending was observed only in a range up to about 20 centimeters in front of the rear wheels.
    It looks as if the Ferrari-Unterboden consists of several parts.
    The underfloor of the Ferrari SF70H still has a special feature. Although it consists of a single piece, it looks as if it were divided into three separate segments from the bird's perspective.
    The mean is significantly higher in comparison to the other two. There, the sensors are also accommodated, with which the temperature of the rear tires is measured. You can see the heel to the other floor parts at a fold in the side view (see gallery).
    Now everyone is puzzling what is hidden beneath it. The imagination is of course no limits. Does Ferrari in this area be about ballast? Are the segments made of different stiff carbon structures? Are installed inside the bulge lines? Espionage photos of competition teams from the Ferrari garage have not yet been able to show anything suspicious. Apparently, at least "foreign bodies" are not integrated into the bulge of the subsoil.
    Why does the Ferrari rear wing have two stilts?
    Ferrari's opponents also claim that the rear wing and the diffuser fold away at high speed. This would reduce air resistance and provide better top speed. In the race, Mercedes and Ferrari were only 0.9 km / h on the long straights.
    Also for this theory, the technicians of the competition have indices. You wonder why the Ferrari as the only car has two rear wing props. Aerodynamically, that makes no sense. "Each prop disturbs the flow. If you have two of them, you are dealing with this error twice, "it says.
    The engineers see the reason for the two pillars to tilt the wing specifically. It is not the first accusation of this kind. Earlier, different teams were suspected of winning top speed with this trick.
    As far as the underfloor is concerned, the suspicions have already spread to the FIA ​​inspectors. There you are relatively quiet at the moment. It is not chiselled in stone that the inspectors only test the stiffness of the floor at the two predetermined locations. The rules allow the FIA ​​to change the inspection stations at any time.
    http://www.auto-motor-und-sport.de/f...-12008634.html
    Little worried the FIA pile ban our floor and rear wing
    Enviado desde mi iPad utilizando Tapatalk
    Go Ferrari, beat them all!
  4. #1534
    We're not the only ones with "upgrades" as everyone else is sorta doing the same thing throughout their cars...but mainly MB and RB is all I am concerned about.
    ahhh :/ what if the Mercs and rb have some super upgrade now im anxious
  5. #1535
    Quote Originally Posted by mwk360 View Post
    I would'nt worry about RedBull during this Bahrain GP; now I have read that renault is due for an engine upgrade coming to the Spanish GP
  6. #1536
    Quote Originally Posted by Aberracus View Post
    I don't think so it will happen. FIA has given the clearance, where have passed the test then only they are able to use it.
  7. #1537
    Sep 2004
    it seems that the technical design team is very aggressive in producing development parts this early in the season. i hope this pays off generously and that this continues for the whole season for a sustained attack for both championships..
  8. #1538
    Ferrari brings major upgrade to Bahrain GP
    https://www.motorsport.com/f1/news/f...ain-gp-893523/
  9. #1539
    I'm liking the developement rate being shown by Ferrari. Most F1 pundits stated major upgrades were expected from most team from the Spanish GP. I'm glad we are pushing them through quickly.
  10. #1540
    Finally! Byrne's super floor we've heard so much about the last few years.
    Seriously though. Ferrari's innovations on this car are truly impressive. Been so long since there has been this much to talk about.
  11. #1541
    Double !!! monkey seat
    Attachment 7079
    Attachment 7080
    Only Kimi used it in FP1.
    May 2012
    Guys i'm watching team press conference and Claire Williams said our former aero guy Dirk de Beer designed our car this year..I mean what..??
    https://www.youtube.com/watch?v=OQjqLiLH_B4
    Around 6:45 mark
    #PrayforMH370 #KeepFightingSchumi
  13. #1543
    Feb 2017
    SÃĢo Paulo
    Strange device on the floor of the Ferrari 2017
    Ferrari is using both the floor of the car and the rear wing, a material, a heat-expansion alloy most likely named NiTi (nitinol)
    But what does and how does Nitinol work?
    There is a brazilian designer named Ubiratan Bizarro Costa Bira, who has a very interesting theory
    Http://designerbira.blogspot.com.br/...soalho-da.html
    March 27, 2017
    Is this one of the secrets of Ferrari to put pressure on Mercedes in 2017?
    The theory of a possible use is there, Watch and draw your own conclusions ....
    If Ferrari is not using this, then I created a device (there in 2011) that could be used in F1. For if I were the designer of one of the squad-side teams, I would not think twice about
    Use the button to enable subtitles
    Design and test something like that. What are you doing?
    Here the beginning of the creation of this strange idea .....
    Http://designerbira.blogspot.com.br/...ojects-de.html
    Here is possible proof, and perhaps Ferrari was inspired.
    Http://designerbira.blogspot.com.br/...2_archive.html
    The theory of the possible "secret" of Ferrari's rear wing
    April 14, 2017
    As I said in the previous video on the theory on the Ferrari floor, now the engineers of the other teams have gotten to question the FIA ​​to check the floor and also Ferrari's rear wing, which according to them, both would be possibly flexing Somehow out of technical standards of racing.
    So would this be the possible explanation of how this device would also work on the rear wing of the Maranello team?
    If that is not being used like that, which I doubt, and that is just a SIMPLE support of the central pillars of the rear wing of Ferrari, then I just created this concept of a strange device for F1, but plausible as far as possible ... Since I am not paid by F1 and I do not need to keep secrets, why not exercise creativity (and language) ......... rsrs.
    Watch the video and draw your own conclusions ...
  14. #1544
    Quote Originally Posted by belfiglio View Post
    March 27, 2017
    April 14, 2017
    thank you
  15. #1545
    Quote Originally Posted by fronaldo View Post
    Around 6:45 mark
    She also said Lance has proved he deserves the seat. She is PR machine, nothing else.
  16. #1546
    May 2012
    Quote Originally Posted by darkchild View Post
    Haha..that certainly hilarious
  17. #1547
    https://www.jamesallenonf1.com/2017/...0-2017-f1-car/
    She is just trying to associate her team with winning. Dirk left Ferrari last summer. So he did not fully design the car. So he left same time James left. So she needs to find out the truth or she is just talking about how good she is to find a "winning" aero guy. I think she is mistaken. We did not have good aero for many years with him.
  18. #1548
    Yea he is guy behind complex, innovative aero solution on Ferrari...And was the guy behind SF15H and SF16H.
  19. #1549
  20. #1550
    https://www.motorsport.com/f1/news/f...ed-893991/?s=1
    I donno why RB are getting 4days that too 2days wet testing & other 2days dry.
    Where for Ferrari & mercs only 3days
  21. #1551
    Allison: "This is not my Ferrari, I left months before"
    https://it.motorsport.com/f1/news/al...-prima-894011/
    Yea, I saw that, and people still keep saying Allison was the master mind!
    Now, as Allison is not the master mind, it is Derk De Beer. He also left almost at the same time as Allison.
    So, does that mean, Derk De Beer is better than Allison that he came up these concepts?
    These people, they have no confidence in the team! We have a decent car. We just need to have a good development during the season.
    Also, 2015 and 2016 cars were not that good. If it was good, they would have won more races. In 2015, we won races because Mercedes messed up, except in Singapore. The aero was not that good, the engine was good, but not the aero. Last year, we went down even more, we didnt win, and Red Bulls beat us. So, does that mean they were so good?
    Every one is trying to find excuse to put our team down. Dont do that, this is a Ferrari forum, if you want to put our team down, go talk in a Mercedes forum or McLaren forum. Please, have some respect for people who work in our team, "FERRARI"
  23. #1553
    Come on how the hell can it be that our possible secrets are out after 2 GP, while in the past RB's was not out for years.....
  24. #1554
    It's just speculation. None of our secrets have come out yet.
  25. #1555
    Quote Originally Posted by SilverSpeed View Post
    sad :(
  26. #1556
    There probably is no secrets, just a well designed and balanced race car.
    Well we must have done something right indeed because you don't make up seconds in a few months, and now that we are front runners again people will focus more on our team to.
  28. #1558
    According to SkyF1's Ted Cravitz, the Ferrari is using the new front wing and the floor. "It is working working well" according to Ferrari!
  29. #1559
    We need some reference to know if the parts are working well, its hard to trust Merc fanboys sometimes, Ferrari won't deny the parts performance i think for PR sake, have yet to see any difference between the sessions besides Vet struggling yesterday
  30. #1560
    lol does anyone remember that one race when they forgot to take Ralf off the jacks during the formation lap? X')
