Page 4 of 80 FirstFirst 123456789101112131415161718295479 ... LastLast
Results 91 to 120 of 2373
Thread: Scuderia Ferrari SF16-H Development thread.
  1. #91
    Quote Originally Posted by NenoX View Post
    (This is a bit off-topic, but I just didn't know where to put it and I don't want to start a new thread.)
    So what was the stipulation again set by Arrivabene if Ferrari wins 3 races?
    Did he make good on yet? HAHA!
    Arrivabene predicted that we would win 2 races 2015 i think. And we managed to win 3. He didn't give a prediction for next year yet.
  2. #92
    Nov 2014
    Quote Originally Posted by Stormy View Post
    I wasn't referring to his predictions for this year.
    I found it, and the team missed it by 1 win.
    We won't be seeing Arrivabene run the hills of Maranello barefoot then
  3. #93
    Actually he said that he thinks we will have 2 wins in 2015,3 will be like a championship to us and if we win 4 it will be somethink so miraculous that he will run barefoot to the hills of Maranello!!!!!!!
    ^This....exactly the context he put it in...so since we did NOT win 4 races, he doesn't have to run bare foot...
    but i like his NEW target for next year....
    Team principal Maurizio Arrivabene did not hold back in a recent press briefing, telling reporters "If you want my honest expectation, it is not to be closer to Mercedes but to be in front of them"
    what can i say....this guy's got some major BALLS....compared to spineless poor excuse for a team principal we used to have before....and that was DOMENICALI.....i never, ever liked that guy; same goes for Marco Matiaci
    Forza FERRARI
  5. #95
    2016 Challenger ...
    Muso corto, sospensioni anteriori a puntone, retrotreno strettissimo e una diversa disposizione della MGU-K: le novità della 667 per puntare al titolo iridato
    31 DICEMBRE 2015 - MILANO
    La Ferrari F150 Italia del 2011 con il push-rod
    L'obiettivo, fissato da Sergio Marchionne è chiaro: dopo aver stupito tutti con un 2015 al di sopra delle aspettative, grazie ai tre successi (Malesia, Ungheria e Singapore) firmati da Sebastian Vettel , la Ferrari nel 2016 deve lottare e (possibilmente) battere la Mercedes nella corsa iridata. Addirittura, secondo il presidente, bisogna cominciare a star davanti a tutti già dalla prima gara fissata - come di consueto ormai - in Australia per il 20 marzo.
    CAPOSTIPITE — Un compito impegnativo, dunque, quello della monoposto 2016 che in attesa del nome definitivo, per ora viene indicata con il numero di progetto: 667. Si tratta di una sorta di capostipite di una nuova generazione di vetture, anche perché la SF15 T in fondo era stata realizzata, partendo da un progetto già esistente anche se ampiamente rimaneggiato. Questa volta, invece, la squadra di ingegneri, diretta da James Allison, è partita dal foglio bianco ragion per cui in questa analisi ci concentriamo maggiormente su che cosa è stata abbandonato del retaggio del passato piuttosto che cercare di indovinare le forme o i dettagli della nuova monoposto.
    SOSPENSIONI — Dopo quattro anni non ci sarà più la sospensione anteriore con lo schema a tirante (pull-rod) ripescata dal 2001 (l'utima scuderia ad utilizzarla era stata la Minardi). Questa soluzione, che era stata adottata per ridurre il baricentro all'avantreno con tutti gli elementi spostati in basso, aveva creato soprattutto nella prima stagione (2012) difficoltà di gestione nell'eseguire le regolazioni di assetto. Si torna dunque al più tradizionale schema a puntone (push-rod) come sulla F150 Italia del 2011 e come su tutte le altre monoposto. Verrà mantenuta la soluzione del triangolo inferiore a forma di diapason già adottata sulla SF15-T, seguendo l'innovazione introdotta nella stagione 2014 dalla Mercedes. Così come della partita dovrebbero rimanere le pinze dei freni anteriori coricate, già viste sulla monoposto 2015.
    MUSO — Anche la scelta del muso lungo verrà abbandonata, allineandosi alle soluzioni del muso corto già introdotte da quasi tutte le altre squadre, anche se a varie riprese, durante la scorsa stagione. Per il Mondiale 2016 la Fia ha introdotto due sole novità tecniche: l'imposizione di uno o due scarichi per la valvola wastegate in maniera tale da migliorare il suono delle power unit ed una maggiore severità nel crash test delle strutture ai lati della testa del pilota con una prova di compressione praticamente triplicata. Un test che ha creato non poche preoccupazioni ai team per il suo superamento. Potendo contare, dunque, su una certa stabilità nelle regole tecniche tutte le scuderie, Ferrari compresa, hanno puntato molto sul massimo sfruttamento di ogni singolo settore.
    POWER UNIT — Oltre alla sospensione anteriore a puntone e al muso corto, Maranello punta anche a una maggiore integrazione fra Power Unit, smaltimento termico ed aerodinamica. Quest'ultima è tornata a dettare legge anche in tema di installazione di organi accessori per il propulsore termico (quest'ultimo deliberato con lo sfruttamento degli ultimi quattro gettoni a disposizione per la stagione 2015 in occasione del GP di Russia) e per i due motori elettrici. Anche l'inedita disposizione dello scambiatore di calore all'interno della V del motore (quindi in posizione alta) potrebbe passare a una zona più bassa all'interno del telaio, seguendo anche in questo caso la moda Mercedes che l'aveva introdotto già sulla monoposto 2014. Lo spostamento della MGU-K, che recupera l'energia dei freni posteriori, è legato all'esigenza di realizzare un retrotreno strettissimo per sfruttare al meglio l'aerodinamica posteriore. Le fiancate saranno ancora più rastremate nella parte inferiore. La stessa sospensione posteriore avrà una maggiore integrazione con l'aerodinamica.
    DEBUTTO — La nuova Ferrari, che sarà presentata non prima della metà di febbraio, debutterà il 22 dello stesso mese sull'esigente circuito di Montmelò, in Spagna, dove è prevista la prima sessione di collaudi 2016. E già allora si capirà se la nuova rossa potrà assolvere il compito affidatole da Marchionne.
    http://www.gazzetta.it/Formula-1/31-...17840209.shtml
  6. #96
    Quote Originally Posted by Anrasp View Post
    What does it say?!
  7. #97
    Sep 2013
    Bulvania
  8. #98
    Nov 2014
    Kz
    'TL;DR' in an image? :xmasbiggrin:
    https://twitter.com/Gianlu_DAle/stat...06856431353858
  9. #99
    From what I can gather, front suspension will be push-rod, short nose, exhaust changes, and engine changes to aid thermal and aero performance and give a tighter rear end, heat exchanger(?) in the centre of the V a la Mercedes, and MGU-K repositioned, but as I'm not technically minded, I may not have used the correct terminology, but I hope it's better than Google!! And that we'll have a real Prancing Horse.
  10. #100
    Launch date is???
    Grazie
    Launch date is???
    Grazie
    Expected around 22nd Feb
  12. #102
    After a year which surpassed expectations in 2015, Ferrari are putting preparations in place to go bigger and better next season.
    In the last campaign, they managed three victories in Malaysia, Hungary and Singapore thanks to Sebastian Vettel and they will be looking to their talisman to deliver once more in Australia on March 20.
    Their task will be dependent, of course, on the car that roars out of Maranello for the new year, which at this moment is known only by its project number: 667.
    It was believed to be the continuation of a project which was started last year but this time, the team of engineers, directed by James Allison, have decided to start afresh.
    That leaves us with an interesting guessing game when trying to determine what form the new car will take. After four years without it, one of the main features is believed to be fronted suspension as well as a more traditional pushrod.
    The nose of the car will also be shorter, falling in line with most of the other F1 vehicles, as they prepare to rid themselves of the long one that has been in evidence.
    In addition to upgrades to the suspension and a shorter nose, all the signs coming from Maranello are that there will be changes to the Power Unit, notably in terms of thermal disposal and aerodynamics.
    Under the new structure, there will be a heat exchanger inside the V of the engine, meaning it is in a higher position, but could be moved to a lower area inside the frame as Mercedes attempted in 2014.
    The displacement of the MGUK, which recovers the energy at the rear of the brakes, as they look to implement a narrower rear end.
    Ferrari’s new car will not be presented before February and is expected to debut on the 22nd of that month, at the Montmelo circuit in Spain
  13. #103
    what???? 22nd of Feb?? are you nuts??? taht is the FIRST day of testing
    Ferrari usually officially releases the car end of January, but who knows, maybe this time they'll REALLY keep it a secret (which is gonna suck for us fans as we want to see it prior then that) and actually show it FIRST day of testing....
    Ferrari haven't actually said anything about launch date that i know of, so who knows
  14. #104
    Thats on circuit at Montmelo for first testing day. But it says not before mid month, so (maybe, if not lost in translation?) as early as 14th Feb, probably online again?
    That would be a little later than usual, wasn't last years about 20 Jan?
    I'm good with a later date if they don't want to give too much away to other teams. :xmasbiggrin:
  15. #105
    Apr 2015
    Italia
    Launch date is???
    Grazie
    February 18/20
  16. #106
    There isn't an official date as yet ... I would assume it to be the 3rd week of Feb. But then ... let's wait and see :p
  17. #107
    Jun 2011
    DC Area
    Quote Originally Posted by abbottcostello View Post
    I don't think it matters. It will definitely launch with the 2015 spec front and rear wings and I wouldn't even be surprised to see it launch with the 2015 nose either.
  18. #108
    C R O A T I A
    Visible changes will probably be: Push rod (if they decide to ditch pull rod), Camera pods(position from 2015 is illegal for 2016), Coke bottle(check to see how much did they manage to shrink it), Nose could be shorter but definitely it won't be final design, and of course wastegate tailpipes(will they use two or one pipe). Wings will probably be latter 2015 spec.
  19. #109
    bulgaria
    Mercedes don't have a heat exchanger in the V of the engine, it's the MGU-H that sits there. Ferrari have the water intercooler in the V of the engine since 2014. I don't know what they are talking about? Maybe they will place an oil cooler a-la Mclaren style in the center of the car behind the engine with a inlet in the roll hoop, to further free up space for a tighter sidepod package.
  20. #110
    Theres a pic on facetube showing a frontal view of a covered F16..
    Not sure how genuine it is but you can see the short nose. Looks mercish from what I could see.
  21. #111
    link??
    Melb, Australia
    Ferrari F150 Italy in 2011 with the push-rod
    The goal, set by Sergio Marchionne is clear: after 2015 surprised everyone with an above expectations, thanks to three victories (Malaysia, Singapore and Hungary) signed by Sebastian Vettel, Ferrari in 2016 has to struggle and (possibly) beat Mercedes in the race standings. Indeed, according to the president, you have to start a star in front of everyone right from the first race set - as usual now - in Australia on March 20.
    PARENT - A challenging task, therefore, that of the single-seater 2016 that waiting for the final name, for the time is indicated with the project number: 667. This is a sort of progenitor of a new generation of cars, also because the SF15 T after all it had been made, starting from an existing project even if extensively remodeled. This time, however, the team of engineers, directed by James Allison, started from a blank sheet which is why in this analysis we focus more on what was left of the legacy of the past rather than trying to guess the forms or the details of the new seaters.
    SUSPENSION - After four years there will be the front suspension with the scheme to pull (pull-rod) fished since 2001 (the utima stable to use it was the Minardi). This solution, which had been adopted to reduce the center of gravity the forecarriage with all elements shifted downwards, had created especially in the first season (2012) management difficulties in performing the adjustments of trim. So it goes back to the more traditional pattern strut (push-rod) as the F150 Italy in 2011 and as of all the other cars. It will be maintained the solution of the lower triangle-shaped tuning fork as adopted on the SF15-T, following the innovation introduced in the season 2014 by Mercedes. Just as the game should remain the front brake calipers horizontally, already seen on the car in 2015.
    Muzzle - The choice of the long face will be abandoned, in line with the solutions of short snout already introduced by almost all the other teams, although on several occasions during the last season. For the World Cup 2016, the FIA ​​has introduced only two technical innovations: the imposition of one or two outlets for the wastegate so as to improve the sound of the power unit and a greater severity in the crash test of the structures on either side of the driver's head with a compression test virtually tripled. A test that has created considerable concern to the team for its overcoming. Relying, then, on a certain stability in the technical regulations all the teams, including Ferrari, have focused heavily on the maximum utilization of each sector.
    POWER UNIT - In addition to the front suspension strut and short snout, Maranello also points to greater integration between Power Unit, thermal disposal and aerodynamics. The latter is back calling the shots in terms of installation of accessory organs to the thermal engine (the latter deliberated with the exploitation of the last four tokens available for the 2015 season at the GP of Russia) and for the two engines electrical. Also the new arrangement of the heat exchanger inside the V of the engine (therefore in a high position) could move to a lower area inside the frame, following in this case also the Mercedes that had already introduced on the seaters 2014. Moving the MGU-K, which recovers energy of the rear brakes, is linked to the need to achieve a narrow rear end to make the most of the aerodynamic rear. The sides will still be more tapered in the lower part. The same rear suspension will have a greater integration with the aerodynamics.
    DEBUT - The new Ferrari, which will be presented not before the middle of February, will debut the 22 of the same month sull'esigente Montmelo circuit, in Spain, where there will be the first test session of 2016. And even then you will understand if the new Red will carry out the task entrusted to her by Marchionne
    22 of Feb is the testing date. What most of you missed is when they said the car will be revealed no earlier than halfway through Feb - so we should see it around on the 15th :)
  23. #113
    Thanks!
    U.S
    Wasn't the tight rear end the main reason why McLaren did badly in 2015?
    Vous resterez toujours en nos coeurs, Jules.
  25. #115
    Quote Originally Posted by TigerKing View Post
    Theirs was size 0!!Our will be size 1-1 1/2!!!!!
    They built a small PU and tried to make it good (McLaren demands).
    We have built a good PU and now makes it small.
    See the difference :)
  27. #117
    Ferrari delayed work on its 2016 Formula 1 car to allow it to fully develop the race-winning SF15-T last season.
    The Italian team bounced back from a winless 2014 campaign to emerge as Mercedes' closest challenger and finish second in the constructors' championship, with Sebastian Vettel taking three wins.
    Ferrari president Sergio Marchionne is confident the delay will not have an impact on it providing a stern challenge to world champion team Mercedes next term.
    "Maurizio [Arrivabene, team principal] will tell you we delayed some things to allow for the 2015 car to be finished," said Marchionne.
    "Hopefully he will not bitch about this. We pushed the start of some of the work on the '16 cars on the chassis, delayed it a bit.
    "But we have had adequate time and adequate financial resources to do the right thing given the rules.
    "So I'm confident we will give Mercedes a run for their money.
    "We approached the 16 car with a very clear idea and very clear interpretation.
    "It is incredibly unlikely that the car will not offer Mercedes a proper challenge.
    "For me to determine whether it will win or not would be very gutsy.
    "I have no excuses to give you this year, in the sense that we started developing the car at the proper time."
    Mercedes won 16 of the 19 races in 2015 as it won the constructors' championship with four races to spare, while Hamilton defended his title with three races left.
    Marchionne concedes Mercedes is still a team to be "afraid of" but he believes the outfit has developed a greater respect for Ferrari following its challenge in 2015.
    "They are competitors to be afraid of because Mercedes is a company which the suitable financial resources to properly manage the races of 2016," he said.
    "They have a high level of know-how so they are not to be underestimated.
    "They made huge progress in 2015, so I'm certain their car will be enormously improved for 2016.
    "We respect them, they are competitors, but we are not afraid of the battle on the race track.
    "I remember at the start with [Mercedes boss Dieter] Zetsche, in spite the fact we are friends, he had a bit of arrogance about Ferrari.
    "They lost a bit of that but not too much because they won the championship.
    "If you talk to him now, I think he now respects Ferrari a little bit more
    "The only way to get respect is to gain it on the track with results.
  28. #118
    From F1today NL (quoted motorionline.com)
    expecting:
    - short nose like the STR10
    - push rod suspension
    - new MGU-K by Magnetti Marelli (smaller and more power)
    - innovative design of the diffuser
    - different front suspension layout to create more mechanical grip and traction
  29. #119
    bulgaria
    Quote Originally Posted by S1000RR View Post
    expecting:
    Now we know that the MGU-K can't deploy more then 160hp, but i don't know if there is a limit on the amount of power that can be recovered during braking. There is a total limit of 2MJ per lap, and on some circuits like Silverstone it would be very difficult to do that with just 160hp.
  30. #120
    I feel the excitment building for the car launches already :)
