they use similar exhaust position as RBs. First position (Acer ducts) will be probably scraped so they can make the back of the car even tighter...
"Ferrari make large modifications on F2012, this is why F. Mass isn't on the track."
thanks for posting that
If we will concentrate our development on blowing the beam/rear wing and not the brake-ducts I wonder how long it will take until Ferrari removes those sidepods tunnels in the back, or at least shrink them.
I think if we would cut off those channels in the back we would have a really compact rear-end.
Massa is setting off too, with hard tyres on the Ferrari.
Massa is eight laps into his current stint, which has mostly been between mid-1m25s and mid-1m26s.
interesting, rosberg starts a new stint on softs and quickly does 1m24.057s +0.547
Meanwhile massa did 1m24.318s +0.808 on the hard tyre..
IM not sure how much fuel was in massa's car and how far into his stint it was..
While rosberg was at the start of his new stint which would probably go for 10 laps
Wow look at the amount of laps allready been done by all teams.
CUT ME. CUT YOU. BOTH OUR BLOOD IS FERRARI RED!
inin contrast to that, where is merc and mclaren blowing thier exhausts?They are not blowing the brakes.they are pointing it at the space btw the brake duct & rear wing,to partially achieve the lost donforce lost by BD ban.
Redbull same as ferrari?
OK, but that is now. I think on other days we tried to blow the vanes next to the brake ducts, so the exhausts were pointing more to the outside. If we finally decide to point them to the space you described (more to the inside), then we should be able to compact/remove that sidepod-tunnel area.
They have been doin that since the beginning.The media thought they were aimin at the ducts.
The exhaust outlets sre also used to remove air entering the sidepods to cool the engine.u need a new engine cover for the other exhaust config.they did not have time to make it,thats one of the reason why they had postponed their test by a day.
There is no double diffuser config allowed under the current regulation, that hole Mercedes has it's probably the starter motor hole, even if they are blowing that hole the benefits are far smaller than a double diffuser.
Have a look at this, the RB uses the suspension to direct exhausts
http://www.formula1.com/news/technical/2012/0/938.html
Its not exactly a DD,but a rectangular step above the main one.
http://t.co/F8bu5GJb
Seems like the general consensus is that the best use of exhaust gas is towards the lower rear wing element or diffuser.
Even Ferrari is looking into it. Won't surprise me if Ferrari abandoned its original idea of blowing those ducts on the wheel.
Hi Guys, I`m new to the forum, massive f1 fan here (Ferrari of course), enjoy reading all your comments and hope to eventually contribute to your great topics.
Welcome! fastcarchar...
New beam wing:
Old beam wing:
But Fer,
Compare this :
To this:
If we decide to use the second one, i still think we can make that exhaust outlet much more compact, and i think they will.
